You pretty much need it all.About the only thing that might interchamge is hold downs if the shoes are the same width.To convert is pretty easy just get complete setup and bolt on.But it might be cheaper to go the disc swap.There should be drum parts used for sale as many have swapped to the later disc.I hate change but adding discs to my 65 was one of the best things I did.Rocky
Chrysler Firepower
