What's the deal w/ having to use spacers or whatever to make sure the pulleys are all aligned when using an ATI damper? I've never been sure exactly what the deal is w/ that...
I have an ATI on my Hemi, I found the damper was farther out than a stock damper, I had to fabricate a mount for my alternator anyways so it wasn't a problem, but the waterpump pulley had to be spaced out from the front of the engine... I have elephant ears and I think I used a 1/4" or 1/2" spacer inside the waterpump pulley, can't remember which....
CrAzYMoPaRGuY
