OK i will ohm out the coil wires. Thats one thing I did not do. Thanks.
Like I said in my original post... If I give it spark it runs fine. As long as the drill is running she runs strong..cam and crank must be working. We are able to drive it around the yard. Everything in my mind is now pointing to that computer which you are reaffirming.. The computer which dodge says is $927
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
