A standard flywheel that matches your crank will work. For a street car I'd look for a standard weight (+/- 30#) steel flywheel. A mini starter that worked before should still work. I'm running the MP mini. I don't believe the Keisler changes starter fit... more a matter of headers and block clearance.
