I failed to mention I run an Autometer O2 gage in my car set to record the AFR on runs. It sure helps tweeking the AFR. 11.44 aint bad for a 2 ton car. But I think your mph is low; however if 6k is the rpm goal and your trapping at 5900 you don't have a lot of leighway there.
