Thanks for all the responses. Thought I would share what I have found out from some other sites.
It seems that the paint texture type used was called a suede finish. The closest matching types available would be to use John Deere Blitz Black or "Hot Rod Flatz" black. Both are a satin/semi gloss texture. Hot Rod Flatz is a urethane and John Deere is an enamel. The John Deere is made for tractors and is supposed to be extremely durable, it's also less expensive.
I see that Nicks Classic Parts is a dealer for the Ultimate Rides Dash Pads. Anyone have any experience with UR pads?
Try restoleum textured satin black. They sell it in Walmart. Friend just did a black dash in that and he liked the texture, sheen, and color better then the custom paint he had made for his OE level resto previous resto.
71 B-body dash pad new using original type process.
https://board.moparts.org/ubbthreads/show...e=0#Post5963116 Their A-body and 68-70 B-body pads are the best on the market.
