did you do the test hot or cold? all the plugs out? WOT while cranking?
Which cylinders, what engine and modifications.
If it's an older engine the exhaust valves may be sinking into the valve seat and not sealing well.
My friend has a 413 Big Block and the exhaust valves wore into the port, past the valve seat
