now post reaction times and we'll see if you need work, car looked good each time i saw it, leaves hard
Reaction times are as follows
Pass #1 .064 I knew I was way late as I had the delay box set up to go red if I was where I should have let the button go
Pass #2 -024 No delay box change and this is what I expected
Pass #3 -.005 Made change to delay box
Pass #4 .027 added to much time
Pass #5 .027 Left box alone should have removed some time but I hate to second guess that darn thing.
I also have much better reaction times in the right lane as I don't have to look across the hoodscoop If I where bottom bulb racing my hood scoop in the left lane would be a real problem.
