1969 RR 383HP stock eng (installed in a 67 satellite)
26in stock california A/C rad
spring in lower hose
160 high flow stat
flex fan
50/50 antifreeze
STOCK WATERPUMP HOUSING
milodon High Flow WP
Stock shroud
for me, the WP housing has changed everything, I had overheating issues with the newer aluminum WP housing (with the bottom opening not to factory spec) now I run 180 all day long in the Florida heat, any time, anywhere.
