Yes, it is the rally dash. Im not sure what or where the voltage limiter is. On the back of the gauges? What might happen if the oil pressure is too high?
The thermostat was new but I guess it's not unusual for new / rebuilt components to not work.
As far as the carb goes there are several adjustment screws on it but I'm not sure what screw does what.
thanks
AM
