I've never asked about drilling throttle plates,I guess everyone isn't as blessed as you and have all the answers.
And the title of this thread is what exactly????
If you don't have any other threads or asked a similar question elsewhere, I apologize. Seems I've seen you ask this in another thread.
You likely have an issue in another system on the car, not in the fuel system. You're trying to band-aid it with the carb. IMO, your combo should idle in the 800-900 range with 10-11" vacuum.
And the "Dan" crack has to do with something else.
