Thanks everyone for your input. I have the original intake on the car. You say I will need a 1/2" spacer for the holley, is this because parts of the throttle linkage hit the choke well? If so can the choke well be milled so that I will have clearence without using a spacer? I have a spare manifold I can hack on!
