My GTX keeps vapor locking after I turn it off (fuel boiling out).
Can you restate exactly what the problem is or the symptom(s) and any evidence for your conclusion. This description sounds possibly like two completely different issues.
ding ding ding we have a winner. You have too much heat in the intake/carb.yes properly setting up an electric to fill the bowls for the next days restart is good but it's about solving the real problem. heat riser? lower temp 'stat? blocking the crossover. cooling system mods? PS I think a carb spacer(wood not alum) would be a major help. Would it be possible for you to run one if you went to a lower height drop base aircleaner?
