What is the VON? (top line) Was it built at Windsor plant? (R in the VIN) What are the Y codes? (Upper right hand corner) What is the engine assembly number (Line 4; left hand side) Any codes in the X section (Bottom row)
A picture or scan would help with your questions.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
