There is a great deal on here right now on a 88mm for sale.The 88 will give you the power you want plus give you alot of room to grow power if you want to later without having to upgrade the turbo. If i didnt already have the 106mm i would have jumped on it for the price.
Posted by the member --- Heads UP
88mm garrett/ air reasearch turbo ran 5.70 @ 126 in my 3300lb leaf spring car on its 5th pass, A/A cooler, blow-thru carb on race gas w/28x10 and 15 lbs of boost. It has a 3.5 in outlet on cold side and 5in v-band clamp for exhaust. I have a 1.39 ar housing that has 10 runs since new and what looks to ge a .96 or 1.15 I'm not sure what it is that came with it included. The only reason for selling is I have just went to a larger turbo. 850$ thanks you can pm me here, Will ship
