Pinch off the heater core hose and see if that makes a difference. Also, if the AC is working all the time, the tail pipe ( by the expansion valve ) will be cold all the time.
Thanks Crizila that did the trick. I guess I need to find a new contol valve as this one seems to be faulty.
