With that in mind, what about a rear axle from a Magnum Or a Viper(narrowed)? I think it'd be easier to use a solid axle and add the floor board hump if needed though.
What type of rear axle did the AWD Caravans have in them? That does sound like an interesting concept. I would love to build a mid-engine rig, but I'm concerned with having enough room for a good pinion angle. If I set the engine/trans in back of the front seats, that doesn't leave much room for a driveshaft, if any. A 3 inch driveshaft doesn't make for very good angles or allow for rearend movement.
Just thinking out loud here, but one way to deal with that is to run an IRS and have the center section solid to the unibody. It would not be a wheelie machine or a dragstrip terror, but you could make it handle.
