i bought a sport comp autometer 2 5/8 water temp the fitting already on the line i think is a 3/8 male flared...the fitting on my big block water pump housing is 1/2 npt i need a fitting to go into the water pump housing 1/2 npt on one side and 3/8 female flare on the other end with hole big enuff for the probe(for lack of better word)to pass into
iv been to a few differnt places today that has fitting (like home de pot) with no luck how did you get around this?pic showing what you did? where did you get the fitting and size??
Did you not receive anything in the instructions that talked about an adapter? AutoMeter offers many options for this. You can buy one that goes in the heater hose or the radiator hose that will allow accurate readings. This can be the easiest, and will let you use your factory set up and the after market also.
PM me if you want any info etc on autometer stuff, I'll give you the name of the person to talk to over there.
