The alternator pulley on Mopars is pressed on. You would need the same type of tool that is used to remove a power steering pulley that is most of the time also pressed on. I believe that the whole alternator has to come apart to press the new pulley on to what I think is called the stator. Any shop that rebuilds alternators would be able to help you with this type of job.
