I am running an Aluminum block 540ci on Alcohol using a Terminator mechanical injection system.
James Monroe from Killer Ron's does not recommend using the seperator w/ Mechanical Alcohol injection as the larger amount of water/oil discharge (compared to a Gas motor) quickly plugs the separator resulting in inconsistent vacuum levels. This recommendation only applies to Ron's injection apllications.
He has been using and selling Star pumps this way since 2004 with no problems what so ever...
I appreciate everyones help and advice, but in this case I am going to run it like James recommends without the separator. James gives great customer service and will stand behind what he sells.
I will let you all know how it goes.
Cheers,
Arnie
