That's very interesting, thank you! I'm working on an early build 70 challenger. Anyone have the dimension for that?
So then, the cruise control harness which used the same hole probably also used a small grommet in 70 and the larger grommet later on?
dimensions of either hole size would be helpfull though. I'm helping M&H collect the info needed to make reproduction harnesses.
Tav
