The motor books will tell you that ALL 1966-to-1974 K-members will interchange. This is partly true as the K-members will bolt in, but the steering angle/pitch is what will bite you if you don't get the correct K-member for your application.
and sway bar was attached somehow diff since 70
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
