Quote: I agree. Sounds like you are missing the thust buttons in the differential. Without the buttons, the axles fall into the housing, and you cannot adjust wheel bearing lash.
The thust button is illustrated in the center and toward the bottom of the page in this link:
so no matter what diff I have (cone or clutch) I should not be able to see through the housing at all. (axles are removed, again) There is a small hole through the center of the SG. If I have to pull the pumpkin, so be it... ugh...
