Actually, I think you are very fortunate that the inner fender is still intact....I had to patch mine up before I could even start thinking about making outer patch panels.....if it helps, you can drill out the spotwelds to separate the two, the area you are talking about should only have 2 or 3 holding it in the wheel well area....once you grind off the paint its easy to see where they are....
