welp, here's the email I sent, and the reply:
Patrick,
That cylinder head with the OE valves and type of springs you want would run $325.00 each for the new EQ castings.
With the Chevy .100" long valves, they would run $425.00 each.
We do not have any good used castings at this time.
We appreciate you contacting CAROLINA MACHINE ENGINES.
Let me know when you are ready to place your order.
You can call us toll free at 1-800-903-6446, Monday - Friday, 8:00 AM - 5:00 PM Eastern time.
Thank you,
Joe Friar
Assistant Manager
Carolina Machine Engines
PO Box 187-171 Lee St
Johnston, SC 29832
800-903-6446
www.cmengines.com
----- Original Message -----
To: sales@cmengines.com
Sent: Tuesday, April 08, 2008 9:39 AM
Subject: cylinder head question
How much for a set of '92-02 Dodge Magnum cylinder heads remanufactured
w/a 5 angle valve job, and with valve springs that would be good to
about .51" lift with a 350 lb/in rate? (I'm thinking, using the
springs/retainers from a GM 3100 V-6 application set up at about 1.65"
installed height with the dodge locks)
Alternately, it looks like you are an Enginequest dealer. how much for
a set of Enginequest 318B heads bare? assembled with a similar
valve/spring combo as above, or using 1.94"/1.625" Small block chevy
11/32 stem, +.100" length valves, and a spring setup good for about .55"
lift with a similar spring rate?
in a follow up email, he said they do their own valve job on them, so I'm guessing they would play with that a bit to get the proper installed height for the springs I requested?
1976 Spinnaker White Plymouth Duster, /6 A833OD
1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!***
2011 Toxic Orange Dodge Charger R/T
2017 Grand Cherokee Overland
2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
