Quote: How much flow does the CNC work show @ .600-.650 lift? How does that translate in horsepower gain? ...With a little suspension work,sounds like a high-10-second ride!
Here is the flow sheet from a set of standard port window MCH CNC Edelbrock RPM heads we purchased.
