EDIT. Also, when sitting in traffic, shift to neutral. The idle will pick up slightly, and the engine will stop lugging against the converter/trans. Both should help cooling at least a little.
in neutral the pump doesn't flow enough,you are better off in gear with the pump at max psi.
