pulled the coil wire and just get the one spark when it won't start and the key is turned off.
Sounds like classic ballast issue sort of but the last time my old truck acted like that it was the ECU
I agree Robert but cooling off wouldn't bring the ballast back to life. It could a coil, ECU, or pick up coil with thermal breakdown. But when the connection in a ballast is burnt off it is gone.
