thanks-I'm open to shoppin around-anyone else have suggestions?
I don't see it listed at Laysons
Turn Signal Switches
This is the plastic switch within the top of the column (includes the canceling cam) and the wiring harness down to the connector That plugs into the main underdash harness
SR-190085 Turn Signal Switch (includes new Male/Female harness connectors) NOTE: 1963 & 1966 year vehicles (all) the connectors at the bottom of the harness are slightly different, but can easily be modified to work
62 -66 A-Body
62 -66 B-Body
62 -66 C-Body
$89.00
