Why is that lifter sitting crooked in its boss
Good Question????
Somethings not right there and a crooked lifter bore, hard to imagine, would wipe a cam in a nanosecond
Have you seen any lifters that were worn on that angle. I have seen them badly cupped, but not like the one he shows. I would check the diameter of the lifter bore and the diameter of the affected lifter. I think this is more than just a typical flattened cam.
I am assuming this wasn't a virgin block.
