well if most remm. i had a post a while back about setting my pinion angle and i did and now i have came up with a new problem....when i use to drive the car down the road and stop and bring it up on the verta it would hit the tire then just burn them up til i got of the go pedal....now i have set my angle to where i thought it would work i have a problem with the carb...when i bring it up on the verta now it will stumbal off the line..( i know that the pinion angle is working cause now it lifts and wrinkle the tire in the road) so being that its hot and all should i jet down and where should i start???right now i have it jetted at 82/fr 6.5 pv and 88/bk and no pv so someone point me in the right way....
