Depending on the weather but, I'll say 12.90 @ 104 MPH
Doesn't that car weigh like 3400+ lbs?
Last year it weighed 3440 with a full tank of fuel, spare tire, and jack. Driver weighed 140lbs. This year, the spare tire and jack are removed. The back seat will also be out for the Classics while it's being reupholstered. However, the wheels are now 15" instead of 14" and the tires are wider, so that added a few pounds. Tires are within a 10th of an inch of the last year's, so gear ratio will be about the same.
