Quote: The more you advance the timing the more it affects your fuel mixture" Okay, how do you get to that conclusion? The distributor doesn't mix fuel. The carburetor does that. Running the advance to the max will not increase fuel pressure, jet size or anything else to do with the carburetor. Too much or too little lead will affect what gets BURNED and what doesn't.
