you'd be surprised how much the car would pick up w. headers and a better intake/carb. if you are going to stick w/ the iron intake, stock carb and logs go w/ the 268. If you plan on upgrades later go with the larger cam. also if you can use the steel shim gaskets that should get you close to 9.5:1. good luck
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
