Re: HP Manifolds heat riser
[Re: KARLN]
#68276
06/06/08 10:13 AM
06/06/08 10:13 AM
do you have a heat riser on your manifold that you're rebuilding? Mine is missing from the manifolds that I purchased so I need to know if everything is included in this kit.
Do not know what the rockauto kit contains, but I am pretty sure now the Chrysler ones consisted of: 2 cups 2 bushings 1 anti rattle spring 1 thermostat 1 counterweight 1 shaft 1 stop (straighter spring) 1 flapper
Here is the Chrysler instruction sheet if anyone wants it.
