Quote: here's my old 383. The new 451 won't look much different.
I was thinking about torquoise and trying to make it look like a 383 since it's only a lowly satellite....Is that an rpm on your's?
Yes, its an RPM intake. The new motor also has Stealth heads painted up to look as inconspicuous as possible, and a massaged 830-DP will live quietly hidden under the original 2-bbl stock air cleaner top section with a 383 "commando" pie tin.
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
