Regarding the "Large Paperweights" cracked heads....What caused you to remove them? Did you blow a head gasket or get leaks into the cooling system? I passed on several junkyard heads when I saw that they were cracked. My machinist said that in most cases, the cracks would pose no problem. I didn't want to risk it.
