1.6 vs 1.5 rocker will not change the seat duration, but will change the duration at 0.050" (and the duration at every other lift point)
Lift increase with 1.6 vs 1.5 = (1.6/1.5)= 1.067
So if you've got a camshaft with 0.484"lift on a 1.5 rocker, it will become 0.484x1.067=0.516" lift with the 1.6 rocker
Seat duration = 0.000" lift Not even a 1.9 rocker will change that. 0.000x1.9 is still zero.
If you look at the duration at 0.050" that does change with the 1.6 rocker, cause the 1.6 rocker increases lift. 0.050"x1.067=0.053" So what the duration the cam had at 0.050"becomes the duration at 0.053" with a 1.6 rocker. And the duration at 0.046875" becomes the duration at 0.050" (0.046875x1.067=0.050)
F.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
