516 heads, which are closed chambered but dont flow as well as any of the heads that came after it (915,906,346,452,902) 350 horsepower, its rated at 10.1:1 but more likely 9.5:1. It will ping at a point on 93 but you shouldnt have serious problems with detonation and should be able to run enough timing to make good power.
Now I need to pin those needles, got to feel that heat
Hear my motor screamin while I'm tearin up the street
