Re: {{{{{{{{{{{ VACUUM SECONDARY QUESTION }}}}}}}}}}}}}
[Re: Quicktree]
#679082
04/24/10 08:59 PM
04/24/10 08:59 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I doubt whether the secondaries are causing the bog issues , air speed needs to be pretty high in order for the secs to open regardless of spring tension , i can't see they are opening when you hit the gas from a standstill , get hold of a paper clip & wrap it round the secondary arm , go hit the throttle till the motor bogs then go see if the clip has moved up from where you placed it , this will answer you're question , good luck.
Adam, the heavier spring fixed the bog...it's gone and tips in perfectly now, so it was opening way to soon, going to try a bigger pump shot as Al suggested to see if it picks up any on the initial hit
Rickster
if it's not bogging I doubt more pump shot will help
I'll let ya know
Rickster
