12.5 is about .85 lambda right? So I should lean it out a little WOT.
Any alcohol numbers anyone want to share?
I plan to get a few runs on the new motor with gas then switch to alcohol.
1.0 lambda would be 6.42 for alcohol; right?
Best power is where in lambda? Still in the .85 range?
Bob
