I do have a set of stock valve covers, however I have 440source heads which have a flat/level valve cover mounting flange where the stock heads the valve cover mounting flange seems to be angled in a bit. So the flange on mine isn't quite straight and they're pretty beat up valve covers anyway. I could hit them with my sand blaster then some epoxy primer when I'm doing my car which will be around the same time anyway.
