I am in the process of putting HP manifolds on my '70 Challenger with 383. When I bought it the car had headers with bolts. I know the factory setup used studs and nuts, but I also know that some big blocks used sleeve nuts as well. What is the correct way to attach the factory HP manifold to a '70 383? If it uses sleeve nuts, what sizes and where do they go? Thanks,
Joe
