For the most part a waste of money.
No.
A waste of money would be ordering one , then digging into the water jacket while relieving the mis-matched drill bit paths in the bottom of the filter inlet bore.
I also have the 5.00 threaded fitting that Canton doesn't supply.
Anyone need them ?
I have the block repaired thanks to Ryan J. and have converted to a remote filter , so this stuff will be a 50.00 paper weight unless I can sell or swap them.
