quick and dirty , not that i can think of without being under the car wit ha shifter installed.
those shifters were before hurst changed the reverse lever so the alignment hole went thru it also and you could just stick a 1/4" steel rod thru them all .
Thats how I adjusted mine. Used a 1/4" drill bit.
but did you have a shifter that had the hole in the reverse lever also ?
