Re: 340 Intake Question Please Help
[Re: daveh1971]
#649874
03/24/10 04:16 PM
03/24/10 04:16 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
purple cam Which purple cam as that's a generic name for mopar cams
LD340, Edelbrock Performer RPM, Rpm Air Gap All these are about the same, great intakes, IMHO Weiand Stealth Good intake once you get the jetting quirks figured out Edelbrock Performer I wouldn't use this one, I'd use a factory iron intake w/ a 1" spacer, before this intake.
There you go, some other input
As far as intake height and shaker, you'd need to measure the stock carb/intake height and figure out the max you can go. The LD, RPM, Air Gap and Stealth are all taller than the factory intakes, IIRC.
