I put down a ground coat of satin black, though gloss is fine too. Then heavy coats of the wrinkle-finish black, which requires heat to properly wrinkle. For a consistent wrinkle pattern, you need to play with the heat. Heat gun works, an oven that you don't ever want to heat food in again is even better. Practice on a similar metal that you don't care about first if you haven't done this before.
