If you mean the upper panel that's visible when you open the hood, my original '68 & '69 Chargers were about a 30% flattened black - slightly shinier than a semi-gloss, but no way a shiny black like what the exterior panels would be on a black car. Not a rich shade of black either, but more like what you see on dipped parts. I wouldn't try to duplicate it with a rattle-can though, the area's too big.
Thanks, I`m definately not using a rattle can on this part. It will be painted using a spray gun once it`s been blasted clean. There`s some of the cars original light green color on some parts of this assembly.
Under Hood Black is also available in quarts for your gun.
1969 Dodge Charger R/T SE - 440 AUTO
