This is what I used. A little pricey, but worked well.
Hey there I was wondering if you can tell me exactly what year,model, and motor this air cleaner came on. I am building a small block with a str-12 manifold and thats the air cleaner. Thanks
As was said mine is an original 64/65 Race Hemi air cleaner. For the money a repro is probably a better deal, most originals you will find would need to be rechromed which adds to the expense. A&A Trans sells the repros in individual pieces, so maybe you would be best just to buy the top and make a custom base as I don't know if the carb spacing on an STR manifold would be the same as a Hemi crossram, kind of doubt it. It would look very cool when done though.
