The '68 & '69 grilles are shaped differently in the center. The '69 hood dips down over the grille where the '68 doesn't. There are a lot of detail differences between '68s & '69s.
I think all that you have to do is put the 69 Hood extension on the 68 hood and put the grille in. I believe the headlamp mounting area is the same and will accept the 69 H.lamp bezels too...
nope...the head light spacing is different between '68 and '69...the '68s are closer together.
